Mozno to nie je az take zaujimave, ked vonku zuri digitalna revolucia, ale urcite stoji za povsimnutie, ako to bolo kedysi, ked este neexistovala kuzelna skratka CCD a bolo treba nafotit a odvysielat fotografie z velkych dialok. V tomto pripade rovno zo sondy, ktora fotografovala Mesiac. Bolo totiz treba nafotit a bezobsluzne vyvolat rovno na sonde
Fotografovanie vo vesmire
Publikováno 20 únor 2019 - 12:38:22
Publikováno 20 únor 2019 - 13:48:57
Zaujímavý je aj proces prenosu analógového signálu a rekonštrukcia filmového obrazu na Zemi:
The satellites carry a film cameras, which can move the film during exposure to compensate for the movement of the satellite.
There is an automated film laboratory on the satellite which develops the film into a negative, using a specialized no-liquid-process.
The developed film is scanned in strips to produce an analog signal using an electron beam and a sensor, this signal is recorded on magnetic tapes and then transmitted to earth over radio.
Back on earth the signal is recorded on magnetic tapes again, then played back on a CRT producing a line image. A film is moved across it to slowly during the playback to capture the image.
This film is developed and carefully laid out on a table. ...again and again... so that one strip at a time you build up the whole image. A photograph of this is taken, developed... but this photograph is part of a larger mosaic!
So it is placed on the floor of an airplane hangar as part of a giant jigsaw, someone goes up on a crane and takes a photograph of that - and now you have a photograph of the moon in glorious detail.
Publikováno 20 únor 2019 - 15:48:49
Díky moc za zajímavý článek. Vźdy jsem si myslel, že ty pruhy jsou protože se objekt "nevešel do záběru", tak jsem s tímhle oduvodněním žil od dětství
Publikováno 20 únor 2019 - 18:34:41
aj v amatérskom svete 'sa dejú veci', pekný koníček. A tiež nákladný.
Tento pán to spojil:
http://nightflyphoto...graphy.html?m=1
Má krásne zábery aj na Pentax 6x7, koho zaujíma astro - kuknite.
Publikováno 21 únor 2019 - 12:11:14
Dobré čítanie (v angličtine) o technickom pozadí prvých fotografií z vesmíru od NASA a o procese digitalizácie začiatkom nového tisícročia je aj na wikipédii, prípadne na blogu LOIRP - to je naozaj detailný zdroj.
Publikováno 22 únor 2019 - 06:35:15
Zrovna nedávno jsem si prohlížel snímky astrofotografa Libora Šmída. Na film třeba:
http://home.zcu.cz/~...mesic/mesic.htm
http://home.zcu.cz/~smid/konj/konj.htm
http://home.zcu.cz/~.../komety/h-b.htm
Publikováno 22 únor 2019 - 07:49:14
A trochu histórie: John Adams Whipple - Daguerreotypia Mesiaca z roku 1852.
